Circuit for OTR Microwave
Posted by daveho (My Page) on
Fri, Nov 27, 09 at 11:41
I'll be installing an over the range microwave where there is currently a simple vent hood. I know I need to run a dedicated 20A circuit, no problem there. The confusion is this. The installation instructions show the microwave being plugged into a single 15A recepticle. I thought a 20A circuit required a duplex 15A recepticle or a single 20A recepticle. I intend to use a single recepticle as I have no need for a duplex. The recepticle will be placed in the cabinet above the microwave. Is there an exception for this situation? The microwave has a 15A plug.
Thanks.
-Dave
RE: Circuit for OTR Microwave
A 20 A single receptacle will cost more than a 15 A duplex.
Just use a 15 A duplex.
It's convenient to have a duplex receptacle up there in the cabinet, a lot of times people have devices that need to be plugged in to charge a battery that can be stored inside the cabinet.
I don't know the current codes - but if the microwave calls for a 15amp circuit are you really not allowed to install a dedicated single 15amp outlet for it?
Absolutely, what else would you install? But I think you have a typo in there. What you're asking is if you can install a 15 amp receptacle on a 20 amp circuit. The answer again is yes. The logic is that you can plug a lower demand appliance into a higher amp circuit. Certainly you could use a 20 amp receptacle but they're typically more expensive so why waste the money.
"I don't know the current codes - but if the microwave calls for a 15amp circuit are you really not allowed to install a dedicated single 15amp outlet for it?"
It actually comes down in many cases to the exact wording of the installation instructions for the MW.
They almost always 'recommend' a dedicated 15 A circuit (or more) for home size units.
A very few commercial models 'require' the dedicated circuit.
What I was questioning was the OP's assumption that he _had_ to run a 20amp circuit for a microwave oven that called for a 15amp circuit.
