| ... grrr... sometimes I hate doing work for friends.
I've inherited a project involving... umm... six? yeah, six hardwired smoke detectors. Wouldn't you know it - only four can be found. We have no idea where the other two went. All the hardware exists - brackets, connectors, etc., but the detectors themselves? GONE. Vanished. Got sucked into a spontaneously-generated wormhole and transported to an alternate dimension. I told him to go buy six new, matching units. He came back several days later with two completely different ones. It is his belief that I should be able to use them. Y'know what? Whatever. I don't care, there's hot and neutral there, I can just leave the interconnect wire disconnected and forget it. His alternate plan is to just use 9V battery powered ones anyway.
- Posted by azlighting (My Page) on Fri, Oct 29, 10 at 2:32
| The manufacturer's don't want you to mix an match, as they say they can't "guarantee" the units will operate correctly or to their maximum operating efficiency, but if you install all their units you can! Shouldn't be a big deal unless manufacturer's have completely different connection guidelines, or wattages, voltages, etc. Def. verify before. |
| Well, I'm TRYING to verify before. That's why I asked. :) |
| Hook it up. When it starts going off or the smokes blow up then you can tell him I told to buy six new matching units. I sure there is probably some code either electrical or fire that requires them to be interconnected and the same. |
- Posted by ontariojer (My Page) on Fri, Oct 29, 10 at 9:04
| You're asking for trouble in my experience. I have found that sometimes different models from the SAME manuf. That are supposed to work together have troubles. I wouldn't even bother interconnecting them if they aren't the same brand.Tell your buddy why though. The funny thing is that the prblems never seem to show up until you have been gone from that job for a month or so! |
| "is the 'interconnect' standard?" No, and that is the problem. There is no standard. |
| well, tell the dummies who made the dangerous tr recs REQUIRED to make a STANDARD. |
| There is a standard. A number of them actually, they just don't apply to proprietary residential smoke detectors. There's a 4-wire standard, for 24V-powered smoke detectors with a set of contacts to report to a central controller that smoke is detected. There is a 3-wire variant, which shares one of the contact terminals with one of the power terminals. There are newer digital serial standards. If I want to turn this guy's house into an office building, school, or factory, then there are definitely standards available. Unfortunately, they require him to buy stuff, something he seems very... uhh... well, did I mention I told him to buy a set of matching smoke detectors and he came back with only two, which don't match either the existing units or themselves??? |
