Sun, Oct 23, 11 at 22:11
| I added a light fixture to an existing circuit in bathroom. I spliced between switch and existing light fixture. Black to black to black--white to white to white--ground to ground to ground. Now new light is on and old fixture glows faintly. When I turn swich on the reverse. Any suggestions. |
- Posted by ronnatalie (My Page) on Mon, Oct 24, 11 at 7:18
| Sounds like you spliced into a switch loop. I bet if you remove the bulb from the fixture neither will light. You need to put that back the way it was (and hopefully that "splice" is in a switch box), and fish the feed to the new fixture from the box on the original fixture. |
