wiring of multi split heating/air units-
peter54321 (
Sat, Oct 29, 11 at 21:04
| I got 2 multi split indoor units and one outdoor18/24 kBtu/h unit . the wiring of the outdoor unit calls for #14 with ground for 208/230v . An HVAC guy told me the cable should be magnetic . Has anyone ever heard of this ? |
RE: wiring of multi split heating/air units-
| What??? Magnetic?? Please do not listen to an HVAC guy when he gives you electrical advice. |
| Somehow the wiring effects the wifi in your house every time the unit comes on . Therefor the special magnetic wire helps . |
| "Somehow the wiring effects the wifi in your house every time the unit comes on . Therefor the special magnetic wire helps ." Bovine Scatology. |
| I think he means shielded wire. But I've never heard of wire used for power being shielded. BS. |
| The indoor units are powered from the outdoor. In mine, the control and power cable between the indoor and outdoor are one and installed by the AC guy. This includes two 208/230 conductors, ground and a 12-24V control conductor. The only thing that the electrician needs to look at is the power supply to the outdoor units. There is a vague warning (stupid drawing) in one install manual to avoid close placement of the indoor units near fluorescent lights and entertainment equipment. |
| "There is a vague warning (stupid drawing) in one install manual to avoid close placement of the indoor units near fluorescent lights and entertainment equipment." Very poorly designed equipment. |
| Upon further examination, they seem to be concerned with two things. The first is the interference with TV or radio. They say that they want 1 M or more distance. Furthermore, they write, " An amplifier might be necessary for the affected device." The second is the fluorescent AND incandescent lights. They want to be as far as possible for the remote to operate properly. Now that I think about it, I have some weird radio reception problems. I will have to check to see if it correlates with the mini split operation. I listen to radio a lot. |
