| electrician is coming tomorrow to wire the kitchen and we are going to put in 3/4 inch weathered brick veneer on a wall and under the cabinets. Will he just set the outlets out more to accommodate the thickness or what? And I plan to set the outlets abov e the counter at a horizontal. Any thoughts here. |
| Make sure he(she) knows what you plan to do. It would be best to have some of this veneer on hand. |
- Posted by azlighting (My Page) on Tue, Oct 27, 09 at 22:23
| Electrician can either mount the receptacle boxes further out to allow room for the veneer, or they can get a deeper box for a few cents more. |
| The problem that occurs is that standard boxes are not set up for arbitrary thickness walls. They have some room, but if nailing flanges are going to be used they need to fall on the studs or blocking. The front edge of the box must be recessed no more than 1/8 inch behind the face of a non-flammable surface. Box extensions are another way of making up for wall thickness. Thin ones go under the mounting yoke of devices and are held by the device mounting screws. You may have to trim the device mounting screw length, but that is a simple thing. |
- Posted by bus_driver (My Page) on Wed, Oct 28, 09 at 13:07
| Adjustable boxes are offered by more than one manufacturer. I do think you are wise to communicate with the electrician about the plans. Too often, it is wrongly assumed that he/she knows all about future plans for wall thickness and finishes. |
Here is a link that might be useful: Carlon
