How much to install reset lights
Posted by sn002 (My Page) on
Sat, Oct 1, 11 at 17:46
How much does it cost to have a prof install 5 reset lights to an existing room? He needs to run wires, close the dry wall and repaint. I am thinking to do it myself if it is too costly to have a prof do it.
Thank you.
RE: How much to install reset lights
"5 reset lights"
Do you men recessed lights?
YES. =)
a pro can likely do it with no damage to the drywall. it probably cost ten thousand dollars
That's about the same figure I had in mind!
Considering the level of detail given in the OP I'd say between $100-$500 each. Sorry guys, I do think $10k is on the high side. lol
Also, I doubt you'll find a real electrician who will patch and paint. In that case you'll want a handyman for the whole job and it will probably cost $200 for everything. Just make sure your HO insurance is paid up. ;)
If the ceiling joists are going in the 'right' direction and only fishing from fixture t fixture is required there will be a minimum of drywall damage.
As soon as you need to run a cable perpendicular to the joists more holes are required since the joists must be bored for the cable, every joist.
