Wed, Oct 5, 11 at 16:28
| It's not recommended, but you can cut off the plug, though DO NOT connect the two wires together. Wrap the ends separately and tightly with electrical tape. Be advised - This will void the UL certification of the light string. |
| If you connect the two wires together you will create a dead short tripping the breaker/fuse and possibly damaging the lights. If you must remove the courtesy outlet seal the cut ends with a waterproof cement such as silicon rubber sealant. |
- Posted by oldalgebra (My Page) on Wed, Oct 5, 11 at 19:58
| Thank you so much for the prompt reply. |
