Adding a flood light
Posted by paco6945 (My Page) on
Sun, Oct 17, 10 at 14:53
I've got an outdoor floodlight (150W) that is connected to a single 20 amp breaker. I want to add 2 more flood lights, with a separate switch to control the new lights.
Is there any problem with doing this? And would I just run the wire for the new floods out of the existing junction box?
RE: Adding a flood light
Done correctly, there is no problem with what you propose, providing the 'existing junction box' has an 'always hot' lead (i.e. one that is not controled by a switch) as well as a neutral and a ground.
just be sure you use 12/2g for the wiring. i would reccomend 12/3g for a loop switch with the neu capped.
