high-current single-pole breakers.
pharkus (
Fri, Oct 15, 10 at 13:31
| Alright, someone just handed me a single-pole 40A breaker... and the only thing that comes to mind is: WHY?
We can't legally install a 40A general-use circuit. What real-world large load would I ever use one of these for? Once you need more than a 20A circuit @ 120, why wouldn't the manufacturer have just gone to 240?
The breaker I've been handed is a quite-antique wadsworth, the kind whose handle SLIDES, so I will accept that its use is equally-archaic, but it still eludes me... and I've seen a 30A single-pole QO before, so apparently they're still around... |
RE: high-current single-pole breakers.
| "We can't legally install a 40A general-use circuit. " Not all circuits are general use. While most larger loads ARE 240 V, there are all sorts of weird things hanging around. |
| I've seen 30A single poles used all the time usually feeding L5-30R's. We used them extensively for larger computer servers. I've got one (I didn't install it) feeding my airplane hangar and I've seen them used for boat/mobile home hookups. You're right, I've never seen a 40A single pole used to my recollection. |
| The only place I have seen 125V circuits above 30A is shore power for marine service. 125V, 50A was at one time fairly common. |
| I was looking for a partial enumeration of the "all sorts of weird things." :) boats and RVs... didn't think of those... Airplane hangar? Is it feeding lights and one or more receptacles directly? Is that legal? That's a BIG computer server! |
| cool! i dont know what it would be used for, but it is different. You could always use it to control a qo 2 space panel wita 2 20a berakers and recs, but you could just use a double pole cb with 12-3G |
| Racks of communications gear sometimes get up well past 30 amps @120 V. They are not plugged, but hard wired. Additional over-current protection is built into the rack of equipment. While running a multi-wire circuit could be used, it adds additional issues with leakage currents between the equipment running on the separate legs. It is easier to just keep everything on a single 120 V leg. |
| A couple of years ago I put in an off-grid solar power system for my sister. The inverter produces 4000W continuous and 8000W surge of 120V power. That is, it's a single pole system and no 240V is available anywhere in the system. The AC panel "main breaker" is 70A. The breaker feeding her barn/utility building is 50A, the feed to the guest cottage is 40A, and the feed to the pump house is 25A -- all single pole. Had to order them on the 'net since the big box stores and electrical supply houses I checked didn't stock anything larger than 30A. |
| Griswold Family Christmas lighting project? :-)
| There are plugs and receptacles available in very large ratings that are seldom seen in a residential setting. |
| The airplane hangar has a separate circuit for the lighting. The 30A circuit feeds a single L5-30R. I don't know the intended use, but that's what the hangar comes with for power. I've got a small breakout box that plugs into it that I run the block heater and a few tools off of. |
