| Replacing a dishwasher in a condo.
Property was built in 1976 or 77. I knew wiring was aluminum, but my research says by time this was built, revised formula for aluminum wiring was compatible with copper. In any event, opened up electrical box in DW, & found evidence
I want to put this back together safely. I read that some *purple* wire nuts are made for aluminum/copper connections.
Perhaps I could put a nice new metal box on wall,
Help ! |
- Posted by mike_kaiser (My Page) on Mon, Sep 3, 12 at 0:04
| Many jurisdictions prohibit unqualified persons from doing electrical work in multifamily dwellings, so you might want to hire a licensed electrician. To answer your specific question you need to use receptacles labeled CO/ALR or pigtail with copper using a approved connecter (e.g., Ideal's #65 wire nut) and then you can use a "regular" receptacle. Make sure none of the aluminum wire's insulation had been damaged by heat and add the appropriate cable clamp to the box. |
