best way to install a heavy vanity light
Posted by per08 (My Page) on
Mon, Sep 21, 09 at 20:43
I am installing a new vanity light. It has three bulbs. It is pretty heavy, about 6.5lb without bulb. I am afraid it is too heavy for a plastic electric box. I want to minimize the drywall damage. Right now I am thinking of three options:
1) mount the light onto the stud, dig a small hole in the drywall near the stud, and connect the wires inside the compartment of the light.
2) use the adjustable all-metal electric box: MB120ADJ
http://www.tnb.com/ps/fulltilt/index.cgi?part=MB120ADJ
It has a metal tab and can be mounted at the stud. It think it is pretty strong
3) mount the light onto the stud, and install a old work plastic electric box nearby for wire connection. The electric box can be covered by the light compartment.
Which is the best solution?
RE: best way to install a heavy vanity light
6.5 pounds is not heavy. 65 pounds is heavy.
6.5 isn't comparatively heavy, but it may be more than a lot of old work mountings can handle on drywall. The plastic ones with more substantial flip out wings will fare better than the bendy tab metal things.
A toggle bolt or hitting the stud in addition isn't a bad idea.
6 lb is the limit for the old work plastic box. See the last sentence at the last page of
http://www.carlon.com/FAQs/FAQ-ZipBoxes.pdf
I plan to mount the light directly onto the stud without any box. Then I will not worry it would fall down someday. Is there any concern in terms of wiring?
The only concern would be if the fixture is rated as a junction box to allow connections to made within the fixture thus not requireing a junction box.
Does the fixture have knock out where a cable clamp can be installed? If not then a box may be required.
I don't think the fixture is rated as a junction box. It has no knock out. Can I use wire staples to secure the wire on the stud?
All connections MUST be made in a box. If the fixture is not rated as a box then you must install a box. The fixture can still be mounted to the wall for support.
I plan to use a metal pancake outlet box, which can be mounted at the face of 2x4 directly.
