| I am replacing a 220 volt Intermatic pool timer with a new one where the timer motor will work on 120 or 240 volts.
The other loads are dry loads that will handle either voltage. I have 240 volts line going to sub panel which has a black, red, and ground wire (no neutral). This is the same wire that I had hooked to my 240 volt timer that I am replacing. Problem is: I want to wire the new timer up as follows....
I did this by installing 2 double pole breakers for the pump and cleaner and a single pole 120 volt breaker for the timer. The problem is the GFCI trips when I turn on the power to the 120 volt timer. Is that because there is no neutral wire for the line? If I change this and wire the timer as 240 on a double pole 240 breker will that cure the problem? Thanks |
- Posted by ronnatalie (My Page) on Tue, Sep 4, 12 at 15:11
| Which GFCI trips? Are you we talking about a GFCI feeding a sub panel? Yes if there is no load neutral on that GFCI, connecting one of the protected legs rightfully gives a fail. The load terminals of the GFCI must feed only their own load and touch NOTHING else. If something touches another circuit EVEN A NEUTRAL or if a NEUTRAL touches a GROUND, the GFCI will trip. Your options: 1. Use a 220V circuit for the timer. Frankly, bodies of water you are going to immerse yourself and your family i s no place for amateur guesswork with regard to wiring and protection. Get professional help. |
