| The builder installed my smoke detector, it has a battery back up. I was wondering if the battery was only a back up or is it something the detector needs to work properly. I am asking because I have 9 ft ceilings and I do not need to be climbing that high at 74 to replace batteries. I does not beep if the batteries run down. |
- Posted by ronnatalie (My Page) on Sun, Sep 18, 11 at 0:32
| It's a backup, but mine do indeed beep when they're low even if the power is on. |
| Thank you, someone told me it wouldn't work if I didn't replace the battery. I didn't believe that, but wanted a confirmation that I was right. The only time mine beeps is when I have a power outage. |
| "I does not beep if the batteries run down." Doubtful. It should beep if the battery is low. If you remove the battery it should chirp all the time. |
| Maybe the battery is still good, it's been over a year since it was replaced. When the power was off it did chirp for a few minutes but soon quit. |
| The batteries will usually last well over one year. The recommendation is to change all the batteries on a certain day that is easy to remember like April 1 (April Fool's Day). If you go this route then have a person come in and change all of them for you. Could be a neighbor, relative, fellow member of any organization you belong to. |
- Posted by ronnatalie (My Page) on Mon, Sep 19, 11 at 7:58
| Yeah, and if one starts chirping , you might as well change them all. My problem is between the smokes and some of the other ancillary alarms (CO etc) it's real hard to localize which one chirped, I hear it, go stand in the general vicinity and wait a few minutes until it happens again, etc... Mine will go a couple of years, but once one starts, I hit them all. |
- Posted by texasredhead (My Page) on Mon, Sep 19, 11 at 13:08
| If the smoke alarms were properly installed, they should be hard wired so all the alarms in the house go off at the same time if only one alarm senses smoke. These alarms have a battery back up if the power should go off. If they are not hard wired, it sounds like you may have a problem. |
- Posted by stinkytiger (My Page) on Mon, Sep 19, 11 at 13:46
| Hi, I have smoke detectors which are hard wired with a battery backup. My experience is that the batteries last for about 3 years. When the battery (9-volt) does run down the smoke detector will Beep. This beep is only once every minute or so. This means it is (a) annoying enough that you have to fix it and (b) it is not often enough so that if you have 10 or more detectors in your house it takes forever to try and track down which one it is. The really bad news is that in a power outage, often in the winter, a number go off. This is because you have no power, so they are on batteries alone, and it is cold, so the batteries' chemical process does not run as fast. So maybe a few go into beep mode. So there I am freezing in a cold house, it is dark. I need a flashlight and a ladder to replace the battery. The Boss (my wife) is not happy. So after lugging the ladder upstairs, and placing it. You discover that the detector your thought it was is not the right one. Listen some more, maybe the other bed room. Oohh the floor is cold. Eventually after getting to the detector you replace the battery. Put the ladder away and get back to bed. 30 mins later. Beep. Yup another one goes off .... Oh well I guess it is better safe than sorry. My recomendation is then when you have a helpful son, cousin, daughter -- "conscript" :) handy. Ask then to replace all the batteries once every two years or so. This method will keep your toes warm..... All the best, Mike. |
| "The Boss (my wife) is not happy" Beeping, what beeping? I don't hear any beeping. If you can find the source of the beeping (to the Boss), I will fix it. |
| I don't think I have a problem, I tested it and it beeps when pushed. I guess the battery was just not strong enough to carry it when the power was off. I can change them, I just don't think it's wise. LOL thanks for the replies. |
| Maybe this is a good product idea for all you sparkies? How about a hard-wired battery backup for hard-wired smokes? Maybe a lithium battery that gets a trickle charge when the power is on and then powers all the smokes when the power goes off. No more 9V batteries, and no more 2:00 AM wake-ups because the battery is low. (I guess you would need a way to monitor the efficacy of the lithium battery) |
- Posted by bus_driver (My Page) on Fri, Sep 23, 11 at 17:23
| First, the NEC does not require smoke detectors. Various building and housing codes do require them. The code with which I am familiar requires smoke detectors to be on lighting circuits. One assumes this is so the circuit will not be turned off and left that way. And a general failure of that circuit would be quickly noticed. The idea proposed is technically possible but would not necessarily meet the existing codes. And I doubt that the market place would buy many of them. |
- Posted by texasredhead (My Page) on Sun, Sep 25, 11 at 9:58
| I agree with bus driver. In Dallas, the hard wiring of smoke alarms is required by the fire marshall. They must be on a dedicated circuit and there are rules where they should placed. |
| I have a similar question....... One of our detectors in our new house (been here exactly 1 yr) is 20 ft up in our 2-story foyer! How in the world will I ever get that battery changed??? I complained to the builder who said that it couldn't be right outside the master bedroom's door--where it should be--because of the air exchange being in that location (small foyer-like area to the bedroom door) but that it still had to be close by (so it's 20' up?). Anyway, anyone know if there's a hard-wired smoke detector available that doesn't require batteries? thanks! |
- Posted by bus_driver (My Page) on Fri, Sep 30, 11 at 13:18
| Assuming that the available floor space under the detector is adequate, a trestle ladder will reach. I have a good one and can reach about 22 1/2 feet when I straddle the top rung of the vertical extension. It is best to have two people to move it in and out of the house. The listed height is the height of the base section. The vertical extension is added to that. |
Here is a link that might be useful: ladder
