ac wiring
Posted by lameduck (My Page) on
Thu, Aug 5, 10 at 21:16
Hi all. Having new heat pump installed. Air handler has 5kw heat strips. Distance from unit to service panel 90'. What size wire will I need? Thanks
RE: ac wiring
I am sure your electrician will have the right size wire.
RE: ac wiring
I am sure he would,but he is out of town. I just need to pull the wire so the insulation can be completed. Thanks
RE: ac wiring
Well, heat pump is not quite enough information to even begin to help you.
Yeah, 5kW of heat tells us something, but what about the air handler?
Also, what about the outside unit (condenser)?
You need to provide all the electrical information on both units before anyone can even guess.
A heat pump is two units; inside air handler and the outside compressor. You are replacing both units?
RE: ac wiring
Usually, the installation instructions provided with the unit will have the information you need. If you don't have the manual (maybe because the HP hasn't been delivered yet), try downloading it from the manufacturer's website.
