Wiring wall oven
doc_scott (
Sun, Aug 14, 11 at 20:50
| I am in the middle of a kitchen remodel and we are replacing a combo wall oven/ micro unit with a new wall oven/ micro that connects separately. The existing circuit that supplied the old setup was on a 50 amp breaker with 10/3 or 8/3 stranded wire. Way more that the new wall oven needs. Can I bump the breaker down to a 30 amp and use the existing wire? or do I also have to reuduce wire size? |
RE: Wiring wall oven
| There's never a problem with having over-sized wire. What does the installation booklet specify for wiring: minimum gauge, number of wires, and breaker amperage? |
| The installation manual was really not alot of help. The plate on the range did state the Kw rating was about 3.8KW and recommended a 20 amp circuit. The wiring scheme for existing will work with 10/3. Should I bump my breaker from 50 amp to a 30 amp?? |
| I would be concerned if the existing 50A breaker was serviced by 10 gauge wires, although I suppose that's a moot point. If it's 10 gauge wire, definitely reduce the breaker to 30A or less. If the device "recommends" a 20A circuit, then that's what you should do. The 10 gauge wires can service the 20A circuit without issue. |
| My bad the wire is 8/3 with a 50 amp circuit breaker. My last question is the appliance Kw rating chart had a different breakdown depending on what voltage either 240 or 208v not sure what my house has. I live in a newer house (97) in a newer sub in florida.... I am assuming its 240v???? |
| 208 is typical only in commercial/industrial 3-phase situations. What is the configuration of your main breakers, 2 or 3? |
| It's almost certain that you have 240V, single phase service, given your description of a house built in 1997. Use the higher KW ratings for the appliance (provided for the 240V service). |
| is the micro 220 or 120? if 120 do you have a dedicated circuit? |
| 208v 2 phase is very uncommon in homes outside of older mixed commercial/residential areas except for highrise buildings with commercial style elevators. |
