Tue, Aug 23, 11 at 14:13
| Here is the PDF specification sheet for my air conditioner. I'm hoping to buy a Brinks Analog timer, and its LRA & FLA need to match (or be higher than) my AC's specs.
What are the LRA & FLA for the below air conditioner? I can't figure it out. Thanks! frigidaire air conditioner And are either of the below Brinks timers advisable for use with the latter air conditioner?
| It would appear that either of these timers has sufficient capacity to handle this a/c. All of the detailed specifications for the a/c aren't provided, but the running current is less than 5A. Even assuming that the starting current is 3 times that, you're still okay. |
| Thanks for your help :) |
