dimmer switch
Posted by sboricic (My Page) on
Fri, Aug 24, 12 at 13:44
I picked up a used dimmer switch that didn't come with instructions. It has 2 red, 1 green and 1 black wire. How do I connect this and which wire is supposed to lead to what? Thanks.
RE: dimmer switch
What manufacturer? What model? Is it line voltage or low voltage? Florescent or incandescent? Electronic or resistive?
RE: dimmer switch
Manufacturer is Leviton. It didn't come with any packaging so I'm not sure voltage, model or type it is.
RE: revised
I took the cover off it and got the info.
Sureslide 6633-p
120 v
Incandescent
RE: dimmer switch
What you have is a 3-way dimmer switch. The wiring diagrams are available on-line if you do a search. The green wire goes to ground, and the black to the hot supply. If you're using this in a 3-way mode, the two reds to go the other 3-way switch. In a single switch mode, one of the reds goes to the fixture, and the other red should be capped off and not connected to anything.
RE: dimmer switch
Thanks for the info. Hopefully I can hook it up tomorrow.
RE: dimmer switch
Below is a link to the PDF of the instructions from Leviton's site
Here is a link that might be useful: instructions
