bx behind baseboard....baseboard popping off!
Posted by calypsochick (My Page) on
Sat, Aug 28, 10 at 9:56
Hi, everyone. We have BX wiring that is running behind our baseboard. Our walls are concrete, and I don't know if they dug out a channel for the wiring to be put into so the baseboard can be flush. But the baseboard looks terrible. I know they are not done with it, but basically the baseboard is popping off the wall. I was told the nails are not strong/long enough, and they need to get some special glue to hold the baseboard in place. Is this normal? Are they supposed to have dug a channel in the concrete wall for the wiring?
RE: bx behind baseboard....baseboard popping off!
Is this an Insulated Concrete Form house? If so, a channel can be made in the foam insulation for the wiring. It depends on the type of interior finish walls. If you're looking at concrete inside, I do not know what is permitted under building codes as far as making a channel.
Hi, there. It's not an insulated concrete form house. It's a Manhattan apartment building constructed in the 50s with concrete walls, and no foam insulation. I know we are allowed to place the wires in the wall, but we just can't cut through any structural parts of the wall. I guess I was wondering if they could make a channel at the bottom of the wall.
YOU can not do anything with the wiring. An electrian can tell you what can be done. You can get oversized baseboards.
It sounds like they already have an electrician who has cut a channel behind the baseboard - but there are problems with the installation.
