Sun, Jul 18, 10 at 22:29
| I have an old fuse box with edison fuses and pull out blocks, one of the fuse sockets have no power going to it, I used a muti-meter to check it and it is dead... I checked the pull out block fuses right above it and they fine...any suggestions? |
- Posted by bus_driver (My Page) on Mon, Jul 19, 10 at 7:23
| Edison-base fuses have incoming power to the center contact in the bottom of the screw shell. Often that contact is a screw that also holds the screw shell in place by means of an insulating washer. That screw must be snug. The screw shell receives power only when a good fuse is installed. |
| I did not notice any loose screws, I did loosen and then re-tighten the screw shell to make sure there was contact. I will recheck all the screws one more time....any others?? |
