Thu, Jul 1, 10 at 16:50
| I just recently purchased a gazebo with pre-wiring for a light. I bought a simple octagonal light fixture that should fit nicely over the octagonal opening in the gazebo ceiling where the wire comes in. However, there is a cross-member bar straight across the celing opening and so I'm not quite sure how to install any type of junction box onto which I can then install my light fixture. If I tack the box to the bottom of this cross-member, the light fixture would not be flush against the celing.
Anyone have any thoughts on the proper installation of a gazebo light? (Even if I were installing a ceiling fan I'd have the same issue) |
- Posted by weedmeister (My Page) on Thu, Jul 1, 10 at 18:05
| pictures would help. |
- Posted by tim_pool_newbie (My Page) on Thu, Jul 1, 10 at 21:22
| I couldn't figure out how to post photos to this forum, so hopefully this URL link to an online gallery of the photos will help. http://cid-7cca53e7b99bfaa5.photos.live.com/self.aspx/Gazebo Light I took various photos of the gazebo ceiling as well as the fixture itself that I'm attempting to install. Someone else indicated there may be a special box for this, but I haven't found anything yet. Any advice is welcome! Thanks, |
- Posted by spencer_electrician (My Page) on Thu, Jul 1, 10 at 22:08
| pancake box. It is 4" and round and is only 1/2" thick. It looks like the 2x4 support is 1/2" higher than the finish surface anyway. |
- Posted by weedmeister (My Page) on Fri, Jul 2, 10 at 11:16
| It's not entirely clear to me, but it seems like the electrical lines are separate from the mounting? And that the mounting bracket attaches to the 2x4 and the light kinda 'screws' into the bracket? Can the electrical wires go inside the hollow mounting 'bolt'? If so, put your box on the other side of the 2x4. I believe you can find boxes that have a knock-out plug in the middle for this. |
| I'd be careful not to block the airflow up into the cupola. This is a factor in the heat build-up in the gazebo (comfort factor). A lighting fixture with a smaller base might be in order. |
