Thu, Jul 21, 11 at 13:50
| Running 6-3 in house from panel then 4 individual 6's out thru 1" pipe to gfi disconnect then 4 individual 6's tub.. correct? |
- Posted by petey_racer (My Page) on Fri, Jul 22, 11 at 16:43
| Sometimes. Care to shed some more light (details) on this install? |
- Posted by ski_d_bump (My Page) on Sat, Jul 23, 11 at 9:15
| I am installing a Hot tub on a 12 x 16 pad.I am running 1" pipe"pvc" from house to disconnect"on pad" to tub for the 4 6g wires. From pannel "50 amp breaker" i am running 6/3 to junction box then flex pipe to lb on outside pipe |
| "1" pipe"pvc" " make sure you have PVC conduit (it is n9t rated the same as pipe for DWV and that it is marked as UV resistant. |
- Posted by mike_kaiser (My Page) on Tue, Jul 26, 11 at 10:29
| Question...isn't an insulated ground is required for spas and pools. Is that all the way back to the service panel? To the OP, you probably don't need a #6 ground. #10 should be sufficient for a 50 amp circuit. Saves a little money. |
