Sat, Jul 10, 10 at 13:33
| My 20kw Generator is located approx 30ft from the Automatic Transfer Switch location. The genset has a double 100amp (each) breaker near the control panel. Internally, the power wires are connected to one side of each breaker. The wires going to the transfer switch get connected to the other side of each breaker. The internal wires look like they are #6AWG possibly #4 (can't make out any size printing on the wire) but its about the size of sparkplug wire and stranded. What size wires would be required to connect the other side of the breakers to my transfer switch 30 feet away? |
| Your inspector might say otherwise, but here it would be fine on #4 copper or #2 aluminum. |
| "The internal wires look like they are #6AWG possibly #4 (can't make out any size printing on the wire)..." The wires inside the unit do not follow the NEC. They can be different insulation that the NEC does not even allow in permanent wiring by trhe NEC . Equipment wiring is covered (at least in part) by NEMA. |
| I would use 2 cu or 1/0 al. |
