| I have a hall light with two 3 way switches but they have not been wired correctly. You know the drill- one turns on the light, the other one will turn off but then the first one wont turn back on unless the other one is switched, etc. MY question is :what are the steps to determine the travelers and the common ? these are rocker switches.
Thanks again |
- Posted by ronnatalie (My Page) on Sun, Jul 17, 11 at 11:03
| The travellers will pass in the same cable the common may or may not depending on the way things are wired up, but if the common does feed back through the same cable as the travellers it won't be connected to the switch on the other end (should be a hint). As you have surmised, most likely someone wired the common terminal of the switch to one of the travellers. The first step is to identify that terminal on the swtich (most likely they replaced an existing switch and assumed the screws were all in the same place on both). Once you've identified the common you usually will find symetry in the wiring on the travellers to figure out which should be connected. |
| Hello brusso There is always a chance that one or both switches are worn out...and must be replaced.. Assuming that the switches worked previously, and that only the switch terminal connections are wired wrong, I advise the following procedure. 1) Turn the power OFF and physically remove both switches, and take off the wires from the switches only. You do NOT have to remove the GROUND WIRE. This will leave 6 exposed wires (3 in each box). 2) Turn the power ON and identify the HOT wire (it will be the only one of six). Measure between each wire and the metal boxes or GROUND WIRE until you find it.(remember this wire) Then turn power back OFF. Mark this wire 3) The HOT wire found in step 2 is the COMMON wire, and goes on the DARKEST screw of the switch. The other 2 wires can go on either of the two remaining screws. Wire this switch (#1) back up and put it back into the box. This switch (#1) is now correct and you can focus on the other switch. (#2). 4) Turn the power back ON and identify a HOT wire at switch box (#2). Then toggle the (#1) switch and identify another HOT wire at box (#2). The COMMON wire at this switch (#2) box is the wire that was NOT HOT . 5) With the power OFF, wire up the second switch, The COMMON, wire goes on the DARKEST screw of the switch. Then wire up the two HOT wires to the two other screws. Hope this helps Let us know how you made out with your wiring project Have A Nice Day |
| Well, thanks to both of you. I found the travelers were in the same cable then followed the steps from linesman. It's all done!!. BTW, this light and switch were not working correctly for at least 7 years. My wife gets back from her trip on tuesday and will be very surprised. Thanks again. |
| OMG! I have now wasted literally almost 2 1/2 days trying to figure this out. Bought an older home & it has some "challenging" wiring...All I wanted was to connect a 3 way switch properly...who knows how long it was wired using an old trick that will make them work using single pole switches...but not right & not to mention, they had bypassed the ground wires. Everything I read online just kept saying to find my "common" wire (which in my past experience always meant "hot"). They all refer to "tagging" the hot wire, but that didn't happen so I just found the black wire that was "hot"! Thank you for finally explaining that for the second switch of a 3 way...It's the not "hot" that is common! I know I should have thought about that...but my question is..."When explaining wiring to a DIY'er...why would anyone assume that we knew this already?" I am so glad I found this forum. Thanks again for saving my sanity! |
