Push-in Wire Connectors Stranded Wire Soldering
Posted by bltglt (My Page) on
Wed, Jul 28, 10 at 2:12
Hi, I am an average homeowner with basic knowledge of home wiring. I've done some of the wiring in my house and have been doing basic home wiring for at least 4-5 years. My question is concerning the Push-in wire connectors and stranded wire. I've always found the wire nuts to be difficult to handle and the whole debate about pre-twisting or non pre-twisting to be mind boggling. I can make a good connection using the wire nuts, but I prefer to use the push-in connectors. I trust them more, and I've had great success with those using solid wire (14awg and 12awg). These connectors are rated for stranded wire (20awg - 14awg), but every time I insert a stranded wire only a few strands go under the locking mechanism. I've tried spinning the stranded wires clockwise with my fingers to stiffen the wire, but the wires still spread when I insert them into the push-in connector. The rest do touch the metal part of the connector by building up in the shape of a ball. However, I have been looking for a better way to do this. I tested out a soldering technique where I used my Weller 40w station to heat the wire up and apply a small amount of Rosin Core solder (60/40) to the very tip of the stranded wire. This seems to hold the strands together so that the wire goes into the push-in connector just like a regular solid wire. My question is, is it o.k. to apply solder to the tip of the stranded wire to hold it together? What does the electrical code say about this? Also, is it o.k. to use this some technique with wire nuts?
RE: Push-in Wire Connectors Stranded Wire Soldering
I don't know of an application where 'tinning' of the stranded wires is not acceptable, or even preferable.
The balling up of the stranded wires as you describe is never acceptable.
Are the push-ins actually listed for smaller sizes of stranded wire?
Thanks for your replys. Yes, the push-ins are rated for stranded wire. Let me list on here all the types of wires that are compatible with it: #18-#12 AWG Solid, #18-#14 AWG Stranded, #18-#12 AWG Tin Bonded Stranded. I assume that Tin Bonded stranded is not the same as a solder-tinned wire because this device can only handle regular stranded gauge wire up to 14 AWG with 12 AWG being too big, especially with solder melted over it. Here's another question, is it o.k. to apply a small amount of solder to the tip of spinned stranded wire that comes on AFCI breakers?
I have some doubts about overall tinning of stranded conductors. Solder is meant to seal and reinforce a connection that's already mechanically solid. It's not as good a conductor as copper.
However, I don't see anything wrong with tinning just the last 1/8" or so of a stripped end to help keep the strands together. In fact I've seen that done on zip cord used in factory-made table lamps.
When connecting stranded wwire to a screw terminal, try twisting the strands counterclockwise instead of clockwise. It helps keep them together while you tighten the screw.
" Yes, the push-ins are rated for stranded wire. "
I see a lot of restrictions on stranded wire.
The number of wires making up the strand, the size of the strands, etc.
I saw at least one that allowed only 7 strand #18.
I have a pieces of 4/0 in my office that has thousands of strands (they are around #38).
It is as limp as a noodle.
It is designed for places that require movement of the wire over a joint.
The only connections it can be used with are fully enclosed screw lugs with a pressure pad bearing on the wire.
At least the visibility in many of the push in connectors allows you to see if strands cam out of the bundle.
My under cabinet lighting is stranded and didn't want to work with the connectors so I tinned the wires. It worked great after that but the current draw is very low.
"My under cabinet lighting is stranded and didn't want to work with the connectors so I tinned the wires. It worked great after that but the current draw is very low."
I hope that is line voltage (120 V) lighting and not low voltage.
Whilst it would appear at times tinning is acceptable (some wires in appliances come pre-tinned at the ends) I don't think it's wise. I have found the connections tend to gain resistance which generates heat, which generates resistance.
Use the twist marettes or an approved crimping connector.
Yes Brick 120v puck lights. I do not think there is enough current to cause a problem in this instance.
"I have found the connections tend to gain resistance which generates heat, which generates resistance. "
Only if you make a bad solder joint.
