Check this out
Posted by hexus (My Page) on
Mon, Jun 28, 10 at 22:32
I did a small office remodel today. Every single receptacle in the place was like this.
RE: Check this out
It made the $5 outlet tester happy.
RE: Check this out
Ground...neutral. Eh, what's the difference? :-)
RE: Check this out
Some people should just simply keep their hands OFF this stuff. Electrical is a case where knowing just enough to make it work is worse than knowing nothing at all.
Seeing sh*t like this makes my blood boil.
To the complete moron HACK that did this, has done this, or is thinking about doing this: Keep your hands off electrical work and call someone who knows what they are a doing!!!
Oh, and nice high quality devices for an office. Sheesh.
RE: Check this out
Iwould like to hear the technical reason why this is not acceptable.
RE: Check this out
The ground is like a spare tire. You've paid for and carry it around and hope you never need it. When you start using it to save on buying a new tire you don't have a spare anymore and if a tire goes flat on you, well, there is no spare, you're stuck.
If something goes wrong on the electric and you've used the 'spare' already, you're dead.
RE: Check this out
I would like to hear the technical reason why this is not acceptable.
Because if the neutral goes open between the receptacle and the panel all the metal parts of the device plugged into the receptacle that should be a ground potential are now at line potential and a shock hazard.
