pool light wiring
Posted by lululu360 (My Page) on
Thu, Jun 19, 14 at 18:13
My pool light junction box is basically in a walkway very near my back door. Like 10 feet away but right in the walkway. It is also ground level sitting in the dirt? is that allowable? I want to move it now as i am installing a new LED pool light ( with longer cord) and first estimate was $2,000.00. Just to move the junction box out of the walkway. Two THOUSAND dollars. HELP. Any suggestions? It is supposedly a PVC line and 120V i think wet light niche.....???
RE: pool light wiring
Junction box must be 6" above ground surface level.
Consider where the conduit is to be routed, how much digging is involved and if it goes under under concrete. There will likely have to be entirely new conduit from the light niche to the above ground level connection, and from there to the power source.
Please, be very careful with this. We've had several people killed in just the last year do to amateur-hour pool lighting installations. Changing a light switch is one thing, tinkering with the wiring in a tank of water you are going to immerse your family in is quite another. The special requirements for pool lights is in Article 680 and not aways obvious to even trained electricians. Make sure you hire someone who knows what they are doing.
Randy is right about the deck box. Sounds like you already may have an illegal and dangerous installation.
