| Hello:
I am renovating an old mobile home from the late 60's. I want to install a 2-outlet GFI receptacle and a switch next to each other in the bathroom. The catch is that the outlet has to have constant power, while the switch controls a light fixture in the ceiling (not the outlet). I attempted to wire the new stuff the same way the old stuff was wired, but the outlet keeps tripping the GFI. Another issue I had was that when I thought I had it working, the led light would come on only when a cord was plugged into the outlet. HELP!! |
| Sounds like you are trying to wire a receptacle to a switch loop... that will never work. What was there before? |
- Posted by BodieDesign (My Page) on Fri, Jun 24, 11 at 16:27
| A switch and a two-outlet receptacle the exact same config. I'm just upgrading. It worked before I put in the new stuff. Could I splice into the main wire coming in so that it powers both the outlet and the switch? |
| "Could I splice into the main wire coming in so that it powers both the outlet and the switch?" What "main wire"? There should be a feed coming into the box with a hot, neutral, and ground. |
