need help getting all the power out of my portable generator
Posted by shelli563 (My Page) on
Tue, Jun 5, 12 at 13:59
I have a Yamaha 6600 de and I need help on how to get out of it all the power.
the unit has 2 Ac outlets for 120 volts at 20 amps, 1 - 30amp outlet L-5 for 125 volts, and 1 outlet 4 prong labeled "120/240 volts"
How can I use all 4 prongs on the 240 outlet to power multipule 120 volt devices? the user manual seems to imply that I can use a 3 prong L-5 in this same outlet - photo of that outlet and its specs is on page 28 of this PDF - http://www.yamaha-motor.com/outdoor/service/viewmanual.aspx?ls=outdoor &yr=0&lid=7&mid=1425
Here is a link that might be useful: 6600de user manual
RE: need help getting all the power out of my portable generator
Sounds like you want to connect a bunch of 120 volt items, but no 240 volt items, is that correct?
I'd first check with the dealer to see if they sell an adapter cable that you can plug into the 120/240V receptacle with something like a power strip with 120 volt receptacles on the other end.
Another option would be to have someone fabricate something, or modify the receptacle, but that could void the warranty, and can be hazardous if not done properly. Check with a dealer for advice first.
You can use something like this splitter:
http://www.amazon.com/Conntek-YL1430520-Generator-Adapter-Connentor/pr oduct-reviews/B002MGJ2F4
Note that it still has only two 15/20 amp receptacles for a max of 40 amps at 120V. A 6600 watt gen will provide 55 amps at 120VAC. You will need to balance the load and you can only get 20 amps from each with that splitter. If you want your full power out, you can get it with a splitter for 30 amp receptacles, which is hard to find and inconvenient. Or you can draw a bit more power from one of the other 120V receptacles on the gen, but not more than 27.5 amps total from either winding, so you need to find out how the other windings are connected to the 120V receptacles.
