most circiuts out overnight
judithbear (
Mon, Jun 28, 10 at 11:31
| Last night at about 2 a.m. the electricity on most of the circuits of my house went out. One circuit remained live. I went to the panel and checked all the breakers - they were all on. Just to make sure, I switched them, one-by-one, off and then back on. No change. My neighbors lights were still working. I went to sleep. When I awoke this morning all circuits are working but of course all the clocks need to be reset. What could have caused this? Do I need to call an electrician? |
RE: most circiuts out overnight
| which one of your circuits was still powered? |
| I think it was the last one in line in the house - the bathrooms. My landscape low voltage lights were still on also. |
more: re: most circiuts out overnight
| I should also mention that yesterday it was hot, over 100+, and the AC ran day and night. The AC has a dedicated 220 circuit in the panel so I don't know how that could be a factor, however, today when the AC kicks in the other lights dim/flicker. |
Are the circuits back on? Was there a storm recently? Can you measure the voltage on the circuits that were down? I suspect an issue with the transformer such that only one half of the box was hot. That is, your house is served by a transformer that supplies you a 'split-phase' circuit. You get +120, -120 and a neutral from the transformer. There could also be a problem with the AC unit which could either be the cause or a result. |
| There is a transformer on the pole. All the circuits are back on today. I cannot measure the voltage, although when I checked last night I suspect there was some voltage because the little green 'trip' lights were still lit on the plugs even though the switches didn't turn the lights on. I'm wondering if I should call my electric co to check on their transformer. |
| Call someone! If you don't even have a way to check voltage you need someone who does! |
