Nashville floods - time to begin repair, have ??
Posted by loves2cook4six (My Page) on
Mon, May 10, 10 at 21:51
Our condo in Nashville was submerged in water 4 feet deep for two days. It is now dry and the drywall has been removed to a height of 5 feet.
We had an electrician over to ask him some questions and it is his opinion that all the wiring and receptacles appear to be working fine but that they need to be replaced due to "water submersion"
His invoice totals $3190 and includes
Remove & Replace 2 outdoor GFI receptacles
Remove & Replace 4 interior GFI receptacles
Remove & Replace 33 interior receptacles
Remove & Replace 15 interior switches
Remove & Replace 1 Range receptacle
Remove & Replace 1 Dryer receptacle
Remove and Replace all electrical wire that has been exposed to flood water
Remove and replace existing switch covers to match new
State Electrical permit and Inspections included
We have two questions...
1. Does the wiring NEED to be replaced?
2. If it does, is the cost quoted reasonable?
3 (I guess I have 3 questions, not two) If it's not reasonable, can you recommend anyone reliable and honest in the Nashville, TN area?
Many thanks for your help. There are a lot of scam and con men going around taking advantage of everyone and we can't afford to become victims.
RE: Nashville floods - time to begin repair, have ??
YES, the wiring HAS to be replaced.
Yes, this sounds quite reasonable. Although prices vary greatly from place to place.
thank you
While the quote is "reasonable", you should always get multiple quotes for any job. Not only does it give you peace of mind, but maybe the next guy will catch something the first missed.
