How do lumens work--are they cumulative?
talley_sue_nyc
More Discussions
My FIL made me a light fixture with 8 candelabra sockets (a friend of his who's a licensed electrician wired it for us).
He put 25-watt bulbs in it, each of them marked at 130 lumens. The package is labeled as "subtle, reassuring light."
The chart on the back says 1050-1999 lumens = "fresh, energizing light," but that's not what's going on here. Do the 130 lumens add up to 1,050?
Since there are 8 bulbs, I thought it might actually be TOO bright, but it's completely not. It's much dimmer than I like--maybe even dimmer than the 3-bulb fixture it replaced (though w/ 60-watt bulbs, it added up to 180 watts).
I'd have had him use normal-base bulbs, but he was nearly done before I knew what he was using, and I thought with 8 bulbs, it would be bright!
There are no shades; do you think I can switch to 40-watt bulbs? Do I need to do some sort of testing before I try it?
I'm not worried about it being too bright, aesthetically--I sew under that light fixutre, and I can't see well right now. I have a dimmer on that circuit that I can use the rest of the time. (I honestly think that reduces some of the brightness even when it's full on, because when the electrician put it in several years ago, substituting his brand for the one I'd pre-pursehd, the chandelier didn't seem to put out as much light.)
mike_kaiser_gw
talley_sue_nycOriginal Author
Murraysville General Contractors · Aberdeen General Contractors · Annandale General Contractors · Bell General Contractors · Binghamton General Contractors · Kailua Kona General Contractors · Leon Valley General Contractors · Marysville General Contractors · North Tustin General Contractors · Tuckahoe General Contractors · Winfield General Contractors · Alafaya Solar Energy Systems · Chatsworth Solar Energy Systems · Fayetteville Home Automation & Home Media · Inglewood Home Automation & Home Mediaweedmeister
brickeyee
