ceiling fan w/ switch
Posted by jvmagic (My Page) on
Fri, May 20, 11 at 16:59
Hi,
I currently have four recess lights in my bedroom with a dimmer switch. I want to install a ceiling fan (no lighting on this fixture). I assume I can tap into the existing electrical wiring from the lights but how do I deal with the switch? Do I need two switches? In the night I'm going to want to have the ceiling fan running without my lights on of course. How is this feasible?
Thanks in advance
RE: ceiling fan w/ switch
Yes, you will need another switch to control your fan independently of your lights. Normally, power is delivered to the junction box where the switch is located. You will want to replace that junction box with a double box, and use the same power source for both switches. Then you'll need to run a new cable from the new switch to the fan. I'd recommend running a 3 conductor cable (plus ground) to the fan so that if you decide to add a light fixture to the fan at some point in the future, the wiring will be all set.
I'd recommend purchasing a book like "Wiring Simplified" before you undertake this project. It's not all that difficult to add a fan, but it would be a good idea to understand the basics before you start.
Is there attic space above the bedroom?
If you are going to use a remote for the fan and possible light kit later you will not need three conductor. Almost every fan I have installed lately, last four or five years, has been operated by remote control, no need to get up and walk to switch and no need for two hot wires.
