Sun, May 16, 10 at 12:47
| We are putting in a concrete patio. Our outside receptacle on the side of the house is a gfci plug (nothing plugged into it). I have two circuits I want to tie into this. One is for a freezer on the patio about 15' away from the plug and the other is for a shed about 100' away. The shed is for a light or small tool use (drill or shop vac). I have run 12 gauge to each. I think I will replace or tie a junction box into the gfci receptacle and then connect the new circuits to the gfci plug. Does this make sense? |
| A word or so on correct nomenclature: A plug is the two or three pronged device on the end of a cord that is plugged into a receptacle(aka-outlet). A junction box is the plastic or metal container in which the receptacle is installed. What type of cable and/or conduit did you run to the shed, and how deep did you bury it? Having a freezer and shop vac on the same circuit could cause an overload and a tripped circuit breaker. A freezer should be on its own circuit. |
| If you go with a chest freezer it should be alright and the freezer can double as a counter/worktable. Plus a chest freezer costs a lot less to operate than an upright. |
- Posted by popcornhill (My Page) on Sun, May 16, 10 at 17:07
| Tks randy. I buried the line to the shop about a foot deep inside 3/4" elec pvc. At the shop I wired into a receptacle. At the house I put a plug on the wire to plug into the hot outlet. Now, I want to change that plug out while adding the new line for the freezer which will sit on the covered patio. The outlet is on a 20amp breaker. It will be a chest freezer hendricus..tks. |
| > At the house I put a plug on the wire to plug into the > hot outlet. Very nice. That should give the inspector something to ding you for when he looks your house over at sale time. I see a quickly contracted ($$$$$) electrician's services in your future. |
- Posted by popcornhill (My Page) on Mon, May 17, 10 at 20:00
| HAAAAAAA HAAAAAAAA Yeah davidr I know when I am in too deep. That was done as a temp light. But ya'll are correct. It is time fer da pros. Seems simple, but the more I study up on this the mixed upper I get. Sooooooooo if I call 911 do I get an electrician? |
