| OK, I am trying to hook up 3 pole switches in two locations.
4 lights in the ceiling are all LED. Looks to me like the power comes in at the first swtch.
The first switch was already hooked up and was not removed during renovation.
I almost always get the same situation where one switch
If there is an experienced electrician out there that can recognize the problem or anyone with ideas what could be wrong - Id appreciate some help.
Thx,
- Posted by mike_kaiser (My Page) on Thu, Apr 14, 11 at 4:56
| The basic idea is that power comes into the first switch and connects to the screw labeled "common." From there two wires called travelers go to the second switch. Power goes out from the second switch, via the screw labeled "common" to the fixture. From what you describe it sounds like you have something amiss there.
| hanks Mike for posting. Thats the drawing that I am trying my darndest to get wired like. I am sure I have gotten this exact combination. Maybe what is a miss is my expectations? I am thinking that someone could turn the lights on/off from each entry AND that if one turns on from one switch that they can turn OFF from the other switch and then come back to the initial switch and turn lights on again?? This I cannot accomplish. Any thoughts yet? |
| To check your travelers take the covers off the switches and the switch that is receiving the power, put an idiot light tester on one of the travelers and the ground. Find the one that is hot and then go to the other switch and the traveler screw in the same location on the switch should be hot. Go back to the first switch and flip it, the other traveler should now be hot, check the second switch and check the traveler screw in the same location, it should be hot. Report back. Hank |
| My two idiot testers are broken so used the dummy bulb test. Looks like one traveler is not getting juice. Looking into this now. |
| Hey I got it. Wires in wrong place on the first switch. THANKS GUYS - great group!!! rvsunn |
