Voltage with the breaker off. Should I be concerned?
Posted by guvnah (My Page) on
Tue, Apr 27, 10 at 21:56
I was replacing an outlet today and double checked the circuit after turning off the breaker. To my surprise, it showed about 6-7 volts. I traced the wire back to a junction box and checked it from there with the same results. The wire feeding the junction box is a 12/3 and it appears 2 circuits share a neutral. What could be going on here and should i be concerned?
RE: Voltage with the breaker off. Should I be concerned?
Bet you are using a distal meter.
The input impedance of digital meters is so high they can read voltage that is capacitively coupled to a conductor in proximity to a hot conductor.
Plug a light into the receptacle and turn it on.
The filament will provide a path for the coupled voltage to ground and you will now measure 9 volts.
The effective source impedance for the coupled voltage is very high, but the multi mega-ohm input of a digital meter can read it.
Distal meters? I always use proximal meters.
Thanks for the response brickeyee. Learning something new every day.
