using a two pole switch in a split light circuit
Posted by uniflow (My Page) on
Fri, Apr 8, 11 at 10:06
Greetings everyone, my thanks in advance for your help. I plan to pull a four wire 240V service to my out building. There are ten identical fluorescent lights that I want to come on at the same time but as two separate circuits.
To balance the load between phases could I run the two legs of a two pole breaker to a two pole switch and then go off the switch to five lights on one side and five on the other? Am I correct that this would effectively cancel netural current so I could combine neutrals and run one white wire back to the sub panel unbonded neutral bar? I have researched multi-wiring receptacles and this seems to fall into that realm.
Thank you again, Jim
RE: using a two pole switch in a split light circuit
"To balance the load between phases..."
You most likely have a single phase 120/240 V service.
It is not a separate phase.
'Balancing' between the legs, especially for small loads is not all that useful.
If you really want to make things more complicated than needed you could use a multi-wire branch circuit with a two pole switch controlling the two legs to switch the circuit.
Make sure you use a two pole breaker (required in a case like this even under the old code rules).
I'm probably missing why you don't want somebody to turn on half the lights? So just having two switches mounted in a double box seems much simpler.
