Taking 1 leg of 120/240v circuit... up to code/safe?
Posted by badmajon (My Page) on
Sat, Mar 12, 11 at 20:03
Hi. I have two welders, one is a standard 240v/22 amp MIG, the other is an odd 120v/26 amp stick/arc welder.
Would it be possible for me to install a dryer style 120/240v 30 amp breaker (the ones with a neutral), and pigtail/split one of the 240v leads and the ground? Then I'd have three hot wires, one neutral and two ground. I'd take the two hots and a ground and put them into the standard 240/30a plug, and the third 240, the neutral and the other ground into the 120/30a plug.
Does that sound like a good idea? Would it be up to code?
The other solution is to simply install two breakers. That's not much harder, but I'd like to simplify if possible given that I won't be operating both welders at the same time.
RE: Taking 1 leg of 120/240v circuit... up to code/safe?
The equipment grounding conductor MUST NOT be used as a circuit conductor. Under certain conditions, that can be fatally dangerous. If you add an appropriate neutral, properly installed, the plan is fine.
A completely different code section covers welding equipment.
Article 630
Like motor circuits wire size is no longer directly set by breaker size.
My basic reading of 630 says that under certain circumstances wire can be undersized based on the duty cycle of the welder. In a residential setting it might be better to run full sized wire to future-proof the circuit recognizing that the next owner might own a different tool and never look at the wire size.
If the MIG welder doesn't require a groundED (neutral) conductor, then you don't need to use a 4-wire receptacle but in this case you would need to pull 3 wire (+ ground) cable or 4 wires in conduit for a neutral required for the 120v stick welder.
