Junction box question
Posted by wtondu (My Page) on
Wed, Mar 28, 12 at 19:53
In my motorhome I have a standard sized junction box (with cover) that has three 12/3 AWG romex runs in it. All three are wires are tied together - three grounds together, three white together and three black tied together with Wire nuts. All are 120V feeds.
I need to install another junction box adjacent to this one with an electrical outlet. I want to add a 12/3 nomex run from the existing junction box to the new junction box / outlet.
My question is can I splice a fourth 12/3 wire in the original junction box? Do I just need to use next size up wire nuts? There is room in the box. What is the proper way to splice 4 12/3 AWG wires? Should I even have four leads in a box at all?
RE: Junction box question
What you have are 12/2 cables (if you are positive they're not 14/2) The ground wire does not count as a conductor in classifying this cable.
There are many 'standard' sizes of junction boxes. You'll need to know the volume of yours.
For #12 conductors, you need 2.25 cu in of box volume for each conductor. (For #14, it's 2 cu in) You currently have 7 conductors (only one of the grounds count) and want to increase it to 9.
Assuming the junction box is big enough, what's the proper way to connect the wires? Just use a bigger wire nut?
Wire nut allowed combinations are printed on the side of the 100 box of Ideal wire nuts.
Or you can use this, courtesy of our fine friends at Ideal Industries
Here is a link that might be useful: Listed Wire Combinations
Or you could try the push-in connectors on page 15 of the catalog below.
Here is a link that might be useful: Ideal Push-In Connectors
"Or you could try the push-in connectors on page 15 of the catalog below."
Wait till you see the price per connective.
