| I am remodeling, and putting in an under sink mount Insinkerator hot/cold filtered water dispenser. The unit runs at ~6.1A.
Is it permissible to wire this to one of my 20A wall outlet circuits? I understand that there is always the possibility of tripping, but really how often will I be using 2 countertop appliances and then decided I need a bunch of hot water? On a related note.
Point is my panel space is extremely limited. I thought I would replace my dryer and hot water with gas, freeing up a significant portion, but the gas supply to the house is 3/4", so..... |
| It's not permissible, and you could always add a sub-panel. Running a dedicated feed or possibly tying into an existing circuit does not change wether or not you need to upgrade your service, it only changes the service calculation when installing a new service |
| I was wondering about adding a sub panel in the basement/crawl space. This would make my rewiring MUCH easier, and I just spoke with my electrical service, and they tell my my line in is rated to 200A. So if I add a sub panel, this has no bearing on my current panel rating correct? that is to say, I can have a "FULL" 120A panel, and then a 60A sub-panel, and that is OK? Thanks Side question: 60A sub panel: 6AWG? |
