| I have a detached carport about 10 feet from my house. I'm looking to install an aerial cable to feed a receptacle and two security lights. (120V, 20A)
The nature of the landscape is such that burying the cable is not an option, but on the plus side, there's no way a vehicle could ever drive under it. I'm curious as to how it should exit the house. (In conduit?) I can go as high as 7 feet initially. It will need to travel vertically until it reaches its required height. What is the required height? What kind of strain relief/connections should be employed on either end? What kind of cable is rated for this kind of application? |
- Posted by ronnatalie (My Page) on Fri, Apr 1, 11 at 9:20
| From the code for heights: The point of attachment to the buildings must also be at least 10' over the finished grade. SEVEN FEET IS NOT GOING TO CUT IT. You're going to have to come out of the building with conduit and attach to an appropriate weatherhead or in some cases a gooseneck. UF if listed for sunlight and supported by a steel messenger would work. |
| Thanks for your response. Sorry about the confusion regarding the 7 foot height. What I meant to say was that since I can have the cable exit the house at only 7 feet, I'll need to find a way to raise it up to the proper height before I can send it across to the carport. It sounds like a conduit with a weather-head would be the way to make that happen. So for the messenger cable. Would I be correct that it is a steel cable that will run from the house to the carport like a guy wire? |
