Is there any good reason I can't cut the plug off and attach the wiring to a switch?
There is a label on the cord that says "Not for current interruption", but I can't think of any reason other than the plug makes sure you have the correct polarity. Also, you think it's okay to splice wire to extend the interconnect wiring 5-6 feet? GE 10169 Slimline 23-Inch Linkable Fluorescent
Thanks,
| Unless you can find a listing for the fixture to be permanently connected it is not allowed for that use. Cords are not allowed to be spliced unless they are very large conductors (like #10 size). Cordage is also not usually listed for permanent use. |
- Posted by biggyriggy (My Page) on Tue, Mar 27, 12 at 16:45
| Thanks for the reply. So if I made a switchable outlet and plugged into that, it would be kosher? And - there is a GE direct wire junction box #24772 that says it is "for direct wiring GE's linkable fixtures into an existing electrical circuit". But as far as I can tell, all of their linkable flourescent lamps are plug-ins. So I don't know if that would do the trick. |
Here is a link that might be useful: GE Junction Box
| " So if I made a switchable outlet and plugged into that, it would be kosher?" That is your best bet, I think, if you want to stay with this fixture. |
