electric water heater keeps tripping circuit box
Posted by goldensmom (My Page) on
Sun, Mar 21, 10 at 12:15
I have a 7 month old Rheem that started tripping the circuit breaker box this past week. This happens after use of a bath or shower. I have it set at 110 degrees. This is a 50 gal replacement from a 80 gal. Is this a plumber or an electrician problem?
RE: electric water heater keeps tripping circuit box
Gray area.
Since it didn't do this from the day it was installed, it is unlikely that it is actually wired wrong. Therefore, a component has failed (I'm guessing top heating element as shorted internally). It's two screws, two wires, and a big nut.
Either is qualified to find the problem and replace it, but the plumber is more likely to already have a replacement in stock, so I personally would aim this at the plumber.
Re-reading your original post, it's 7 months old, there's probably a warranty, so call back whoever installed it (most likely a plumber).
