Cost of plugmold??
Posted by mick2 (My Page) on
Sun, Mar 27, 11 at 8:26
We are doing a kitchen remodel and my electrician wants to charge us $225 per plugmold. That seems really high to me, any opinions??
RE: Cost of plugmold??
It can be a pain in the rear end to install, so the easiest way to say no is to make it expensive. "Per plugmold" doesn't tell us much, could be a 30ft run or a 5ft. run. Accordingly, $225 may be reasonable or not so reasonable.
Really high? Depending on your area I seriously doubt it.
Plugmold is a real P-I-A to install, and I get a premium to install it. There is also the fact that if it is the oly thing on a circuit, in a kitchen it will require a GFI breaker which also adds to the cost.
It is also pretty expensive to buy, so if that price includes the material I think it is a bargain.
had nothing to compare it to, so thanks for your input-now I know.
Also, compare it to how much he'd charge for the receptacles. My Dad told me that in his area (less expensive than in mine), a single "box" runs about $125 to $150.
So if he's installing plugmold, he IS installing a box, actually, but then he also has to connect the plugmold to the box, etc.
One run of plugmold ought to be less expensive than the 6 outlets it replaces, however. THAT is its cost advantage.
"...a single "box" runs about $125 to $150.."
where? I may move there.
talley_sue_nyc, your logic, and math, is flawed to say the least.
Installing W/M is NOT installing a box, nor do you need/use one for it.
