Which glue?
Posted by corgilvr (My Page) on
Fri, Mar 18, 11 at 6:50
I need to reaffix a glass globe to the metal ring of a light fixture. It's damp rated and uses a 35 watt halogen bulb if that makes any difference. Any suggestions?
RE: Which glue?
Probably going to have to be a two part epoxy. Check the packages at your local hardware store. The optical guys use a two part epoxy for glass to metal bonding, but the stuff they use will be scary expensive for you (the minimum order is probably more than your lamp is worth).
RE: Which glue?
The problem is going to be the heat from the light.
Heat will weaken even epoxies (and MANY other glues) long term).
At least do a search for 'high temperature glue' and see what you can order.
There ARE epoxies rated for higher temperatures.
Ceramic based adhesives are more common for this application.
You may be able to find someone who selling single tubes/containers.
Is the metal to glass bond holding the weight of the glass?
RE: Which glue?
A lot is going to depend on the size/weight of the glass. If it is small and light a hi-temp silicone may work also.
RE: Which glue?
Loctite 349 Impruv Light Cure Adhesive
RE: Which glue?
Just home from work. You guys are the best! Retail on the fixture is $239 and that would be my cost to replace it. Brick, I remember you from years ago!
