| https://lh6.googleusercontent.com/-gyOs02MQ0tM/TysJOM6SXBI/AAAAAAAAAAo
/-PvAO4Ef-vw/s640/100_0507.JPG
https://lh3.googleusercontent.com/-sVaY4qqWsQk/TysJMzv8RJI/AAAAAAAAAAg /RsRrYeatOAI/s640/100_0509.JPG How do I properly connect these? All web sites I've seen talk about white with green/blue/or orange stripes. These wires have a single stripe running the length of the cable. One white with a single blue stripe, one white with single green, and one white with single orange. The rest are solid colors. Anyone? (In the second picture, you can see the blue stripe) |
- Posted by yosemitebill (My Page) on Thu, Feb 2, 12 at 22:23
| It appears that you have 3-pair wiring coming to the wall jack. Assuming it was wired correctly at the NID (network interface device) - where the telephone company connection terminates at your residence - the pair sequence is: 1st pair - Blue/White w/tracer --- 2nd pair - Orange/White w/tracer --- 3rd pair - Green/White w/tracer. The wiring for your jack would be as follows: Orange/White - to - Yellow/Black (ring/tip) respectively. Green/White - Not used However, you MUST check the other end to confirm it was wired correctly at the NID. |
- Posted by weedmeister (My Page) on Fri, Feb 3, 12 at 17:52
| sometimes it is blue with a white strip and white with a blues stripe. Sometimes it is solid blue and white with a blue stripe. so it would be Blue and White/Blue, Orange and White/Orange and Green and White/Green. |
