Grounding Outdoor Sub-Panel
Posted by Sander1 (My Page) on
Sat, Feb 25, 12 at 13:02
We have a Meter and a main disconnect with Ground; at 130' distance we plan to install an outdoor sub-panel. would it be right to run 2 hots and 1 neutral to the sub-panel and use a Ground Rod for Grounding the sub-panel? ...Thank you!
RE: Grounding Outdoor Sub-Panel
Under the newest NEC all sub-panels require a 4-wire feed.
The exception allowing a 3-wire feed to another structure if no other metallic connections are present was removed.
If the sub-panel is attached to the same structure it has required a 4-wire feed for a very long time.
