| Thanks for taking the time to read my post...
While looking at clothes dryers/washers (future purchase), I noticed that Miele dryers come only with a 4 prong (four wire) plug already connected to the dryer itself and there is no way to alter this setup for safety reasons of course.
Thanks in advance to any advice you can throw at me. |
- Posted by ronnatalie (My Page) on Sun, Feb 27, 11 at 16:37
| First off, check to see if a proper ground isn't in fact present. In that case it's just a matter of placing a 4 conductor receptacle. Otherwise, you'll have to pull a new cable. You'll have to see whether you want to do the range. Not particularly any reason to do so though. Cost is highly variable. Best bet is to get estimates and references. |
- Posted by weedmeister (My Page) on Sun, Feb 27, 11 at 17:18
| Are you sure the dryer does not allow you to remove the cord and replace it? |
| "I guess safety codes have changed and a 4 wire system is now the new standard for all dryer manufactures." No, most dryers stil lcome wihtout qa cord and have instructions for eoither 3-wire or 4-wire installation. |
| ronnatalie...I don't think there is a ground (or ground wire) in the 3 wire run from panel to dryer. It's the old flexible metal type of casing around the 3 wires (2 lines, one neutral). The block on the dryer electrical connection is grounded to the dryer cabinet. WARNING- Improper connection of the equipment grounding conductor can result in a risk of electric shock. brickeyee...you're right (quickly checking out Electrolux & Whirlpool's web site instalation instruction manuals) they still provide 3 wire, hard wired applications. So I guess I really don't have to worry about updating the line unless I decide on purchasing the Miele dryer or I just want to update to current code. Thanks! |
- Posted by ronnatalie (My Page) on Mon, Feb 28, 11 at 6:37
| If Miele says it nees a 14-30R, you need a 14-30R. It's not up for negotiation. Have an electrician pull the proper wiring. Frankly, since it doesn't look all that involved, and I suspect that as time goes on you're going to find more units like the Miele with that restriction, I'd go ahead and fix it. If you want the Miele drier, get the Miele drier. Love the Miele coffee station I have and my next dishwasher will be a Miele, my neighbor has one and it is the quietest thing I've ever seen. |
