Under Cabinet Lighting - Opposite Walls - One Dimmer Switch
Posted by kathy_wa (My Page) on
Sat, Feb 27, 10 at 9:04
Doing some hard-wired under cabinet LED lighting, pretty straightforward except for one issue. I've got a short run of kitchen cabinets on an opposite wall that I'd like to also be controlled by the same ELV dimmer switch. I think it can be done this way:
Dimmer Switch -> 14AWG in wall to Cabinet Junction Box - > 1st run of Under Cabinet Lighting (~20' linear cabinets) ->Cabinet Junction Box ->14AWG in wall over to opposite wall ->Cabinet Junction Box -> 2nd run of Under Cabinet Lighting (~2').
I was planning on using the Phillips eW Profile lighting and it seems they even offer a handy junction box to do this with:
http://www.colorkinetics.com/support/userguides/eW_Profile_PC_Switched _Junction_Box_Install.pdf.
It says it can do up to 50' continuous run and apparently the transformer is built-in.
Hopefully some kind person can give me some advice. Thanks :)
Here is a link that might be useful: Phillips eW Profile LED
RE: Under Cabinet Lighting - Opposite Walls - One Dimmer Switch
Sure, it looks like it should work. You could also run two 14-2 runs from the dimmer to each section of lighting.
Awesome, thanks! Might actually be easier to just do the second run to the lighting on the opposite wall, thanks for the suggestion. :)
The junction box you linked has a switch in it. You don't need a switch if you have a wall switch. They do show links at both ends so you should be feed through to the other set.
Both sets will be controlled by the same switch however.
Yikes! thanks for pointing that out Joed - that is the wrong box. The installation instructions show the right one (altho I don't see any reason not to just use a regular outlet box with a plate).
" The installation instructions show the right one (altho I don't see any reason not to just use a regular outlet box with a plate)."
If you do not want blank plates scattered around for junction boxes you can also use the kitchen counter receptacle boxes a junction boxes fro wiring the under cabinet lighting.
Watch carefully for box fill, and you might even have to use 4 inch square boxes and a plaster ring for some of the counter receptacles to get a large enough box.
Since the runs to the under cabinet lights are all 120 V, all the regular NEC rules apply, but having different circuits share a junction box is allowed.
Thanks for the tip, brickeyee about the shared junction box.
In this case, I plan to "hide" the junction boxes inside the upper cabinets. Just have to get that cut just right in the cabinet :)
