Two circuits, one box?
Posted by kudzu9 (My Page) on
Wed, Feb 5, 14 at 4:21
I'm remodeling and making some minor changes to a 20 amp circuit that I intend to extend. I took out a receptacle at the end of the run and have a free piece of wire that isn't long enough to make it to my first new receptacle location. However, nearby is a large plastic, electrical box on the wall that has a sconce mounted on it and one 14/2 w/g running in to it from a switch on a separate circuit. Since there is plenty of volume in the box for more wires, and I can reach it with the end of my free wire, I'm considering bringing the end of it into this box, splicing it to another piece of 12/2, and running this new piece on to a new receptacle box from there.
I would simply be using the box for the sconce as a junction box for this separate 20 amp circuit where I wire-nutted two pieces of 12/2 together. Is there any problem from a code compliance standpoint of having these two separate circuits sharing one box as long as I don't exceed box fill requirements? Also, I presume that I just wire nut the two grounds in the 12/2 together, rather than wire nutting them to the ground for the 14/2 cable...correct?
RE: Two circuits, one box?
No problem so long as box fill limits are not exceeded. If circuits of different voltages are in the same enclosure, there must be a partition between them. In residences 120 and 240 volt circuits do not require partitions since the voltage to ground is 120 in both cases.
Here is a link that might be useful: Partitions
bus_driver-
As usual, thanks for the good advice.
