| Hi Everyone:
I will try to make this as clear as possible but it might be long, so my apologies in advance!!
I rewired one of the two old 3-way switches in my house recently but may have a problem. The switch is setup S1--Light--S2 in a long hallway. The switch I rewired was at the end of that chain (marked 's2' above). It had typical nm-3 cable with white, black, red, and ground wires present. I wired it as per the instructions on http://www.acehardware.com/info/index.jsp?categoryId=1284746 (step #9) as that is what the situation appeared to be. I was too dumb to take a picture of the old switch and have since learned my lesson...so I followed the instructions above thinking it would be a simple job. Anyways, long story short; red wire went to the black screw marked common, black and white wires to the other two terminals, and the ground to the green. Problem is the switch in the beginning of that chain (S1) now must be on for the switch I rewired (S2) to function. If S1 is turned to off, then the light wont go on or off when toggling S2. Conversely, if S1 and S2 are both on, and I turn OFF S2, the light goes off but now the first switch does nothing instead. So basically I have a case of one switch doing nothing independently of the other one, and probably some crossed wires in there. I'm guessing this is because my common wire is not actually the red wire, but one of the other two - is this the likely culprit? I do not know if the power is going to the switch or coming from the light, is there a way to tell using a volt meter? MOST IMPORTANTLY, how dangerous is it to leave it like this for a few days? The switches are both turned 'off' (circuit panel is still on) and the house is unoccupied for a few days, so I'm mostly nervous about an electrical fire here. No sparking or smells or anything while I was there, but still pretty uneasy about it knowing something is mixed up. I'd like to get an electrician in there next week if necessary but I just want some piece of mind the place isn't going to burn down in the meantime. Any thoughts? Thanks for any help! jay |
| Well, after a little more reading it sounds like I just dead ended it, would you agree? Could there be another explanation? Much better understanding of what is going on now, but I'd still like a little reassurance if anyone can let me know if there is / is not a problem here! |
- Posted by bus_driver (My Page) on Mon, Feb 27, 12 at 8:14
| The first thing I would do is swap the red and black wires on the switch screw positions. See if that solves the problem. |
| Hello lj987 : Let us know how you made out with your wiring project Have A Nice Day |
| Hi Linesman: Isn't there any danger or issues with putting the hot wire on the wrong terminal though? What's the worst that could happen if the wires on this switch are are wired to the incorrect terminals and I switch it on - is it like I blow a fuse/trip the breaker bad; or is it I get the shock of a lifetime bad? Thanks! |
- Posted by bus_driver (My Page) on Wed, Feb 29, 12 at 15:06
| Amazing!!! lj987 had no concerns about the wrong wire when he/she was doing the switch change out. But is concerned about the requested responses. And apparently has not put into action any of the advice offered. I keep asking myself why I even bother to try to help people who ignore advice given. Neither my suggestion nor that of the linesman will create any problem. My next suggestion is to call an electrician. |
| Hello lj987 If you turn OFF the breaker before you move the Hope this helps Let us know how you made out with your wiring project Have A Nice Day |
| Isn't there any danger or issues with putting the hot wire on the wrong terminal though? Well, after a little more reading it sounds like I just dead ended it, would you agree? Yep, that's all you are doing till you follow directions given. |
| bus_driver; I asked twice if there was any danger in my initial two posts and you did not respond to those concerns. I also stated that I am not at the property currently and thus, have not put any of the suggestions into action. Simply telling someone to switch wires based on color when it's unknown what is being used as the common and hot sounded pretty sketchy to me, especially when one individual suggests moving the black wire and the other one suggests moving the red. My apologies for this concern, I DO appreciate everyone's advice, and am glad to know now that it will not cause any problems or pose any threats should the wrong wires be in place at the wrong terminals. As someone trying to learn as much as they can about simple wiring I think safety should be paramount, especially as this was a mistake on my part, and I hope you can sympathize with my initial concerns. I will make the changes this weekend and report back. |
| I considered myself lucky for not having problems with the initial wiring, and am trying to be safer / much more educated on what I'm doing the second time around, hopefully learning my lesson and gaining an understanding of what's actually going on here instead of relying on wire colors. Thank you all for your advice and response. |
